cheapo dvi card?
ccotenj
need a cheapo card with dvi output to use a 1905fp at work...
no gaming, just basic office stuff...
suggestions from the masses?
preety much any card has a dvi port.
If it doesn't matter one way or the other then you should probably get an ATI card because the DVI ports on the low-end NVIDIAs ain't so hot. See here and here for more info on the subject. A Dell 1905FP is 1280 X 1024 so you probably won't have problems but you might as well get one with better DVI outputs since there's no price difference. Something like a Radeon 9250 like this AGP version.
