BellaCroix
- Mar 25, 2004
Was wondering if anyone could recommend the cheapest, quietest pump that will accept Innovatek 8x1 (1/4" BSP Thread) compression fittings?
Yes, I know that usually looking for the "cheapest" pump is asking for problems however the project I'm sketching has a series of non-functional reseviors that I'd like the water to circulate in but that I don't want to sacrifice flow rate to connect them all to the actual cooling loop.
I've considered setting up two seperate loops but it's really not worth the added expense of a quality pump and additional radiator at this time and, if it's needed in the future, I'll just build the second loop later.
All I need is a very inexpensive, quiet, pump (that's not going to blow a seal and spray water all over everything).
Any suggestions?
Any suggestions?
