Cheapest power supply for my current build?
piscian18
I5 4690k stock
Corsair H50(modded with an additional 120)
W7 U 64bit,
GA-Z97X-UD3H-BK,
2x8GB 1866 vengence, 2x Asus 280X DCII OC,
3x 27" Acer G276,
2x1TB Raid-0
2x1TB,
2x120GB Agility 4
NZXT H440,
CORSAIR CX750M
I'll want to run eyefinity occasionally so I'll need to run my 4690 to 4.0-4.5? for that. Otherwise nothing else special. I'm assuming my 750x is subpar for the task. I can't afford anything fancy I was hoping to keep it under $100. Any recommendations?
Pretty sure unless you buy used you are not going to be able to get a good higher wattage power supply than what you already have.
I would try it with your current power supply.
Do you have an i5 4690 or 4690k?
750 watts is more than sufficient even with overclocking. As for whether it's necessary to overclock or not... in general, the higher the resolution, the less the CPU becomes relevant to performance.
ok just looked to confirm its a 4690k, if I can do it without overclocking that'd be nice.
This is the PSU I'm running CORSAIR CXM series CX750M 750W sorry corrected my op.
That CX750M should be more than enough for your system.
As for whether or not overcocking is needed, it really just depends on the game. Most games simply require more GPU power to run higher resolutions. A few games need more CPU power to run higher resolutions. It just depends.
The cheapest PSU for your rig is the one you already own.
0 dollars
