I'm curious to see what the cheapest cost of entry to a 4-drive NAS would be. More than 4 SATA ports would be a bonus for future expandability, but if we boot off of something that isn't SATA, I'd entertain only 4.
I have an old P4 box which could work, but it only has 4 SATA ports, has high power draw compared to a modern low power build, and only has 2 GB RAM, sending me back to FreeNAS 7 / NAS4free. If this can be done cheaply, I'd think about doing a new build.
So, how low wattage and low dollars can we go, while still providing a good handful of SATA ports, enough 3.5 bays (between 4 and 8), and a PSU that won't melt down?
Thanks for any suggestions [H]'ers!
FreeNAS
Would like to see if it's possible to do this for cheaper than a QNAP or Synology box
Canada. So, online: newegg.ca, Ncix, etc. Nearby: Canada Computers brick&mortar store
Case, PSU, motherboard, RAM, CPU
None. Could reuse an old case to shave dollars, but let's ignore that for now
6) Will you be overclocking?
No
None
No plans yet, just want to see how this option stacks up against pre-built NASes
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Lots of SATA ports, to delay the addition of a SATA controller board
Open source OS
FreeNAS
No
None
Open source OS
