capmonolith
- Jan 17, 2015
My current PC is 6 years old and I'm planning on upgrading. Dota2 and WoW are the only games I play so I'm looking for something as cheap as possible to play them. I already have an nVidia GTX 560 I'd like to reuse.
Dota2 and WoW would be the only games I plan on playing.
My budget would be around $300
Arizona
I need a CPU, motherboard, RAM, and possibly a power supply. I have an almost new Corsair 430CX psu that I would like to use if it is powerful enough.
For the CPU i was thinking of the Pentium G3258
For the mobo I was thinking of the GIGABYTE GA-B85M-DS3H but I plan on overclocking and don't know if it's any good for that.
RAM is whatever is cheapest and good.
I will be reusing a GTX 560, Lancool PC-k59 case with 4 case fans, dvd-rw drive, 2 TB Western Digital Black, some WD 640gb, and monitor, mouse, keyboard.
6) Will you be overclocking?
Yes, on stock cooler.
]7) What is the max resolution of your monitor? What size is it?
24 inch 1080p
As soon as possible.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Atleast 4 sata ports and 4 usb.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I have Windows 8
Arizona
24 inch 1080p
I have Windows 8
