Cheapest PCI Express card?
torvalds
What is the absolute cheapest pci express graphics card that can be bought? I dont care how powerful or anything else just cheapness.
Ok. Just one question: these will work with a 16x PCI express slot wont they?
bobsaget said:
Get a refurb 6200. I got mine for 50 bucks off newegg.com
Now it's 59 shipped.
http://www.newegg.com/Product/Product.asp?Item=N82E16814145109R
This card will be many times better than the x300. When overclocked, I can't tell much of a difference between it and my old 9800 pro.
I'm not sure if this is a wise idea.
According to the first post, the poster didn't care about performance or anything like that, just the price. So, there's no reason to get a 6200 other than gaming. Also, he'd be taking a chance going with a refurbished because it may still be broken or newegg may make a mistake. (search around, it's happened before)
I think you'd be happier with the card I suggested.
