Cheapest P55 Build
rivacom
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
Gaming, Video Streaming/production.
Cheaper the better
3) Where do you live?
NY(Upstate)
CPU,RAM,Motherboard
Hard drive, DVD, Case, Powersupply, GTX 460
6) Will you be overclocking?
no
24", possibly 3 24" in the future.
Next month or so.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I need USB 3.0 and for it to be a P55 or X58. SLI would be a plus.
Own Win 7 64bit already.
So I purchased a Black Magic Intensity. Which I thought I'd be all set with just a PCIe usb 3.0 but apparently it's required to have a P55 or X58 board.
So I guess my only option would be to get rid of my current build and upgrade to a new board/chip/memory.
Currently I have a E8400 with I believe a GIGABYTE GA-P35-DS3L with 4 GB of ddr2 800mhz corsair memory.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
I figured I could sell my current setup and upgrade but what would be the cheapest setup that would be similar to my current config above? SLI would be a plus if it didn't cost too much more.
Lets see here. There an Intel Core i5 760 cpu at Microcenter for $169.99 in store. As far as mobo with USB 3.0, GIGABYTE GA-P55-USB3 for $119.99 on Newegg. Then, get 4GB DDR3 RAM for $39.99
No HT support on the Core i5 760 cpu though.
Or, do a P67 chipset mobo with Intel 2500K Sandy Bridge cpu for $179.99
Note: No HT support on the 2500K cpu also.
MOBO + RAM combo for $211.98
love the prices but in upstate there isn't a microcenter around. Only electronics store we have is best buy.
