you would need either PCIe(2 displays)+USB devices for monitor output(uses a lot of CPU processing)
or an ATI 5xxx/6xxx series card with 3 ports, 1 at least being displayport
ati 5xxx/6xxx series allows for 3 or more displays. up to 2 legacy displays(VGA/DVI/HDMI), the rest (3rd monitor and up) must use displayport. If you dont have a displayport monitor, you need an active adapter. the cheapest active adapters (DP->singlelinkDVI or DP->VGA) are around $20-$30. If you need DuallinkDVI(>1200p), then it'll cost you $60-$80 for the adapter
active displayport adapters:
dp->dvi
dp->vga
5xxx/6xxx series, cheap
(if you want all digital connectors, single slot. might need to buy some HDMI->DVI adapters from monoprice)
~$60 + $30 adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150508&cm_re=5550-_-14-150-508-_-Product
(if you want a mix of digital and vga, single slot)
~$60 + $30 adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102875&cm_re=5570-_-14-102-875-_-Product
(if you want 5 displays, single slot, need an active adapter for each monitor above 2)
~$150 + adapter costs
http://www.amazon.com/XFX-Radeon-DisplayPort-PCI-Express-HD577XZ5F3/dp/tech-data/B0048DAPXC
~$220 + adapter costs
http://www.newegg.com/Product/Produ...1358&cm_re=eyefinity_5-_-14-131-358-_-Product
(if you want 6 displays, dual slot)
~$300 + adapter costs
http://www.newegg.com/Product/Produ...2888&cm_re=eyefinity_6-_-14-102-888-_-Product
