Cheapest C2D Machine possible!!
Goran
Looking for the cheapest thing I can make for my little brother.
What I have so far:
AG Neovo 19" 4ms Widescreen Monitor
DVD-ROM
Lite-On CD-RW Drive
Keyboard
Mouse
Speakers
60GB HD but I think its iffy... and its 5 years old
Basically I need to choose
Case, power supply, processor, graphics card (onboard maybe?), motherboard, ram, anything else...
Keeping this very low budget. If I had to choose a number I guess no more then $400
Currently I have chosen:
CPU: E4300 - $169
PSU: Fortron 350W - $30
Motherboard: Either Foxconn P4M9007MB-8RS2H - $57
or ASUS P5VD2-X LGA - $55 cant really decide. Both are quite barebone. Can either of these overclock?
Case: COOLER MASTER Centurion 534 RC-534-KKN2-GP - $50
Ram: WINTEC 1GB DDR2 DDR2 667 - $65
Video Card: BIOSTAR V7302EL16 GeForce 7300LE - $50
Total: $418.45
or if I go with the Foxconn mobo I can take out the graphics card and use the onboard and be at $370. Does anyone know how good the onboard video is?
A little high but if its not possible to go any lower that may suffice... Realistically I would like to get it closer to $350. Suggestions and critiques welcome :D
Will you be overclocking this machine or just leaving it stock? Also, what will this rig be used for?
Just threw this together on Newegg quickly:
CPU: E4300
http://www.newegg.com/product/product.asp?item=N82E16819115013
Motherboard: Gigabyte GA-965GM-S2
http://www.newegg.com/product/product.asp?item=N82E16813128024
RAM: 1Gig Corsair Value Select
http://www.newegg.com/product/product.asp?item=N82E16820146580
Case/Power Supply: Antec Sonata Rev.2 w/ Antec SP-450 PSU
http://www.newegg.com/product/product.asp?item=N82E16811129155
There are probably better builds out there but I don't thikn they'll differ much from this one. Price comes out to be about $450 though. Has onboard video too...
I may overclock it. If I can safely squeeze any more juice out of it I'll be more than happy. Also my little brother will be using it for school work mostly. He does play some old games like counter-strike 1.6, starcraft, diablo II, serious sam, and some other not very heard of games. Currently he uses an old HP with a s423 p4 1.3Ghz and 128mb rdram, geforce 2, and it works ok for those games
For that budget, you'd be better off with an AX2 3600+ Brisbane. What resolution does your little bro play at? Look into the XClio 450W instead, its only 8 bux more for a pretty solid unit. Though, all you really need is the FAR Ultra 500W from Fry's. So, I'd wait around for the FAR PSU as well as the FAR Ultra ATX Case, also from Fry's. That saves you around $75 right there. The case is on sale right now, so get it while you can:
$0 - Ultra Wizard Black Mid Tower Case ($40 - $40MIR; free shipping)
WAIT for this PSU deal... it comes aroudn ALOT:
$0 - Ultra V Series 500W Power Supply ($40 - $40MIR; free shipping)
If you can't wait, go for this one instead:
$38 - XClio 450BL ATX 450W
Here's the AM2 Build I'm suggesting:
$150 - COMBO: AMD Athlon 64 X2 3600+ + BIOSTAR TFORCE 550 Socket AM2 ($24 combo discount)
$30 - Zalman CNPS7000B-ALCU 92mm CPU HSF
$67 - Patriot Signature 1GB (2x512MB) DDR2-667 PSD21G667K
Otherwise, go for Smititty's Mobo/CPU/RAM suggestion. Do you have any old DDR400 ram and an AGP card to use instead? If so, go for the AsRock 775Dual-VSTA instead.
For that budget, you'd be better off with an AX2 3600+ Brisbane. What resolution does your little bro play at? Look into the XClio 450W instead, its only 8 bux more for a pretty solid unit. .
this.
also, you could probably get away with using stock cooling. pick up a few extra case fans and you'll be good to go.
No Fry's near me. Ill look into the brisbane tonight. Off to work :D
Alright heres an update. The PC has for the most part stayed the same. I decided that for the price I may as well go with a case with an internal psu as a combo. Turned out that saved me quite a bit of money. So with the current build I could even look at getting more ram or maybe some fans and what not.
Heres the updates hardware list:
Rosewill R804BK Black Steel ATX Mid Tower Computer Case 300W with 24 pin connector Power Supply - Retail
WINTEC AMPO 1GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory Model 3AMD2667-1G2-R - Retail
Foxconn P4M9007MB-8RS2H LGA 775 VIA P4M900 Micro ATX Intel Motherboard - Retail
Intel Core 2 Duo E4300 Allendale 1.8GHz LGA 775 Processor Model BX80557E4300 - Retail
Subtotal: $316.47
All I can really say is WOW! Thats low budget!!! My only concern is the onboard video. I could not find any reviews for it online. Does anyone know "S3 Chrome9 IGP" performs? Can it support current games? What should I expect it to be on par with? Thanks! And let me know what you guys think of the changes.
Just a fair warning, that LITE-ON cd-rom, i have it, and my pc shuts off when i try to burn a cd. Just my 2 cents on LITE-ON.
This one works fine. It has been in his old machine for at least 2 years now without any issues. Basically he has a DVD-Rom drive and the Lite-On CD-RW drive. No issues with either as of yet and both are 2 years old or more
The S9 thing will play no current stuff at all. Why don't you buy a cheaper processor and mboard and get a semi-decent graphics card?
