Hello,
I'm trying to build a cheap ZFS server. AMD seems the way to go with ECC support since Intel require expensive server motherboards. So far I'm there :
MB : ASUS M4A78LT-M LE ( 6 SATA ) => 42€ / 60$
CPU : Athlon II X2 250 => 40€ / 57$
RAM : 2x2go Crucial ECC unbuffered ( CT25672BA1067 ) => 55€ / 78$
Total : 137€ / 194$
What do you think about it ?
I'll go with a 1068e card on the PCI-E 16X + 8 to 10 Samsung F2E 1.5to in either 10 raidz3 or 2 different vdev.
Do you think the CPU is powerful enough to handle this ?
Thanks in advance,
Nolhian
Total : 137€ / 194$
Thanks in advance,
Nolhian
