Cheap Xbox style controller that is wireless?
matt167
I’m looking for a cheap controller that is worth trying. I have a some offshore brand of Xbox style wired controller that is okay but I really want a wireless controller. I game at this point perhaps 5 times per year ( I haven’t booted a game beyond two point hospital recently).. I would like to get into the original RDR since I’ve never played and Mafia TOC. So I may see ‘some’ decent use but not a ton. I also game in the winter months if I do. Is there a cheap controller that is worth it? Or should I just keep using my 10’ extension cable hidden under the carpet ( wife hates it )
I'm not sure what your budget is or what you consider cheap however take a look at the 8BitDo. I've been using one since 2023 and I've had zero issues with the controller. The wireless version is currently $52.99 on Amazon. https://a.co/d/7c7kNdS
You game 5 times a year and you put a cord under the carpet? Just put the cord and controller in the closet and then take it out when you use it.
Well, it’s been wrapped up in the cabinet for 6 months or so.
Cheap Xbox style controller that is wireless? I'd vote for a wireless Xbox controller. The Xbox series controller has Bluetooth built in or you can pick up a wireless dongle for it.
Unless it has changed the Wireless Xbox controller requires 2 AA batteries to function as a wireless controller. Matt167 mentioned that the controller would sit unused for long periods of time so the AA batteries would drain while not in use. A minor annoyance but something to keep in mind. This is what pushed me to purchase the 8BitDo version, no batteries required.
Replacing batteries isn’t a deal breaker since my wife buys alkaline batteries in larger packages to have on hand. But rechargeable would be a plus. Realistically I’m thinking I might get through a game this winter. Once the leaves drop off the trees and there’s nothing to do outside
I would just take the batteries out and put them in a charger next to where the controller is stored when not in use. Of course, they'd have to be rechargable batteries, and you'd want a charger that's smart enough not to overcharge them.
Better than leaving in, and coming back to a corroded battery mess because you forgot about it for 6 months to a year.
The 8bitdo controllers come with a li-ion battery for less than the Xbox controller, and they all have hall effect sticks. The Xbox controller still uses pots.
I dont understand why all the console manufacturers eont use hall effect joysticks. If a $20 9-bit do can included then the $70+ console controllers can also. Other then them wanting to sell you another $70 controller ever couple years.
Honestly, a good pot joystick is just fine. Sure they don't last forever and they may have some quirks, but they are at least consistent. A bad hal sensor or magnet, or a stray magnetic field can fuck up a hal effect joystick, and then you are all wonky until you recalibrate. Hopefully that fixes it.
