Cheap Web browser system: suggestions?
dbr1
Web browsing 90% of the time or more. Maybe some photo viewing only.
Like to keep it around $250 or less
US, Bend Oregon
MB, memory and CPU, PSU. No graphics card needed, will use onboard graphics.
Monitor: Planar PX 2611W. Case: Lian Li PCV35.
6) Will you be overclocking?
No.
1900x1200
Very soon.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Want to keep it Intel socket 1150.
Will be using Win 7 64 bit.
As stated, will be a nearly entirely web browsing system. No games required. Could at some point also be used to run in 24/7 mode for IP camera application Blue Iris. Want it to be as inexpensive as possible but functional.
This is to replace an old socket 775/Wolfdale E8400 system which was adequate for the job but seems to have reached a terminal failure. Prefer socket 1150 unless there is a compelling case for AMD.
Have you considered a Chromebook? They are in your price range and more than adequate for web browsing.
The "compelling case for AMD" is that AMD processors have better embedded GPUs than similarly-priced Intel processors.
Since you don't need much to begin with, you don't need to spend more on an Intel-based platform.
Here's the AMD buid:
$48 - AMD A4-6300 dual-core processor
$50 - MSI A55M-E35 micro ATX motherboard
$40 - Kingston HyperX FURY 4GB DDR3 1600 RAM
$40 - Corsair CX430 430 watt power supply
$178 - Total before taxes (includes free ground shipping)
If you really want Intel, replace the A4-6300 and the A55M-E35 with the following:
$57 - Intel Pentium G3220 dual-core processor
$50 - MSI H81M-E33 micro ATX motherboard
You're spending $9 more on the Intel processor.
What are you (re-) using for storage?
This
EDIT: I was going to suggest an Intel NUC but 250 USD is too low of a budget. If your budget was around 400 USD, Intel NUC would probably be overall best route to go.
The computer will be used to drive a 26 inch monitor at 1900x1200.
Also, Win 7 because it will be on a home network with Windows machines for file sharing/remote access/etc.
