Cheap upgrade for Supreme Commander
cyberslag5k
I would like to play Supreme Commander, however when the number of units in the game increases, the game's performance slows down to an unplayable rate. Early in the game, everything runs beautifully, though, even with every video setting turned all the way up at 1280x1024 (including 4x anti-aliasing).
I'm not long out of college, so things are VERY tight right now, but I might be able to swing a small upgrade.
I'm running the following:
Proc: AMD Barton 2500+
Mobo: ASUS a7n8x-e
RAM: 1GB Corsair DDR400
Video: GeForce 6800GT (256MB, AGP)
I figure my video card is up to par, which is good because that's big bucks I don't have to spend otherwise. The only down side is because it is AGP I'm limited on my upgrade options on the other fronts. I'd think the PC3200 RAM is sufficient too, though it could use a little company.
So do you guys think it's doable to add a stick or two of RAM, and swap out a new CPU and AGP motherboard for not too much cash, to get me to a place where I can play a large game of Supreme Commander at a respectable rate? Any suggestions on which CPU and Mobo to look at, as well as how much memory to look at?
Thanks in advance!
True, though the thing I feel I'm only lacking on is the CPU. I'm eyeing the Core Duo processor, as it runs on that nice, versatile 775 chipset, so I can get the mobo features I need while still allowing me to up my proc to some dual core lovin'.
