Cheap TV tuner and remote
The_Bob
I have Comcast cable(not digital cable but analog) and I want to buy a tv tuner and a remote but I dont wanna spend to much. What is a good TV tuner? I like ATIs remote is it any good?
The WinTV-Go cards are less than $50.
I remember seeing them in the $35-40 range a while back @ CircuitCity a while back.
It really depends, if your just looking to dabble in PVRs, and dont mind sub par quality, any cheapy tuner will do, just go to ur local hardware store, I know the fry's by me has as many different cheapy tuners as baskin robins has ice cream =). But if you want good quality, definitely check out the Hauppauge PVR 150 (like CrimandEvil suggested).
Typically surpluscomputers.com had the wintv-go for $20 shipped, but what are you going to use it on? MCE, Meedio, what? Some of those don't work with software cards.
A cheap MCE card is the emuzed maui. I can be hard to find, but I only paid $35 for it... works ok...
