Cheap Speakers (2.0)
ooze
I've decided to give my ageing game PC to a relative. It'll lack speakers so I want to add a pair. She's already staked out where it'll go and there's place to have two small speakers of the bookshelf kind. A sub wouldn't be bad, but I think it might get in the way. I'm looking for something very cheap but not crap - around $400. Self powered would undoubtedly be best so I was looking for reviews on some powered monitors but many of them look huge. Is there anything you would recommend?
killernoodle said:
Do you mean $40 and not $400? $400 is a helluva nice set of speakers.
It's all relative :p
Talk to BossNoodleKaboodle if you are interested in powered monitors, he seems to know more about them than most here. I personally have no experience, but there are a good number of bookshelves in that price range, assuming you do mean 400$ =]
If you might be looking to upgrade in the future, you might want to get passive monitors and an inexpensive receiver. Will you be looking to add a subwoofer in the future?
is there no way to connect active monitors and a sub together without a reciver/amp
and if you have powered monitors and a reciver couldnt you just connect the speakers to the monitor out and the sub to the sub out?
That would work just fine. Also, you could get a sub that has low-level inputs and connect it that way, so it would highpass the output at 80hz or whatever and output that signal to the monitors.
$400 (£250). As someone else said, it's relative. For me $20000 is a helluva nice set of speakers. I think it's a reasonable amount to spend on something that's not complete crap, especially as I'm giving this away. Sizewise I asked her and apparently there's two side shelves on either side of her desk about 10" wide/deep. It should ideally fit on there.I don't have to max out the budget either. I think it should look and sound decent, that's all.
Check out HTD, they have their level 2,3,and 4 speakers on clearance. I have a 5.1 set of the level 3's in dark cherry, they are quite nice.
Might I then assume that this product shoudl be availible in the U.K.?
Yes please. Most things are - but they just tend to be overpriced compared to the US.
B&W is british, no?
I've no experience with their product lines though, but everyone generally seems to think they are pretty good. I honestly have no idea what's available overseas...and it certainly isn't any of the internet brands that I have the most experience with [unless you want to spend all that cash for shipping]
Got a reco from a friend: M-Audio BX5. Anyone have anything bad to say about these?
