My main desktop/gaming computer doubles as a HTPC. Until recently, I've had it hooked up to both a 1080p lcd monitor and a digital projector on the two dvi ports on the GTX 275 card. Unfortunately, one of those two ports seems to have died, and I don't like having to dig back behind the system and swap cables on the one good port any time I want to watch stuff on the big screen (aka my wall).
At first, I figured one of these would do the trick: http://www.amazon.com/gp/product/B001VLBARO/ref=oh_details_o01_s00_i00
After all, the monitor and the projector are both 1920x1080 native, and cloning the image should work fine. Unfortunately, I didn't count on Windows 7's over-zealous PnP monitor detection. I can get both displays working properly as long as they're both on, but if I turn either one off, I get nothing on the other one. If I could just hack Win7 to put out a constant 1920x1080 60 Hz signal and just ignore what PnP is telling it about what I have plugged in, it should work. However, that doesn't seem to be possible as far as I can tell.
I really don't want to buy a new video card right now, and switch boxes always seem so over-priced for what they do. Anyone have any other ideas on a cheap way I can fix this?
