cheap panaflo fans?
illig
I'm looking for some cheap 80mm panaflo fans, of the Low Speed/Low Noise variety (commonly known as L1A models) for several computers i'm about to build....
I used to buy these things for $2-3 a piece at the most, however prices seem to have skyrocketed!
The lowest prices I found were $5
here: http://www.casecooler.com/vanstealquie.html
and here: http://www.directron.com/80l1a.html
Does anyone know of a store that still has them for cheap? I'm starting to get desperate, as it seems that i'll need to spend 2X of what i originally set aside for the fans...
any help appreciated!
I actually just got some of these and I ordered mine from: http://www.jab-tech.com/customer/product.php?productid=1852&cat=&page=1
I got 6 of them for $30.
However I did not find these fans to be as quiet as everybody says. I found myself putting only 6 volts to each one. So Airflo must not be high but at least they are as quiet as I wished after that. After all I do have 6 all together.
Now I can sleep with my PC on. :)
Also one other good thing about getting them from there is that they come with the 3 pinned wires connected to them so that they are not just bare wires like most sites.
-haryy
how did you get it so that it only runs 6 volts? I need to build a machine that no one can hear. As close to silent as possible. Harddrive is going to be loudeds thing... no heatsink fan... its a celeron 400, so it shouldn't matter. As for the main rig, going to get zalman heat sink
-haryy
Do you mean 7V? 6V would be quite hard to do but the difference the +12 and the +5 is 7.
I have a fan controller on one were you can adjust the volts to werever you want (check with a meter). The other ones have a big resistor in the power wire so that it doesnt allow so much power to flo to them.
My computer is extremely quiet and I would tell you to get a Seagate Barracuda V. I have 2 120 gig's of these and they are extremely quiet. I also just bought a 200 gig Barracuda Seagate drive from CompUSA for $100 and that is pretty quiet to. You can hardly here a thing with my side panel on.
I love being able to sleep easy and have my computer on at night.
-haryy
If you buy all of those off of Ebay and add them up and say that you are getting 6 total then your total is: $41.5
I got 6 of these same fans from http://www.jab-tech.com for a total of $30.
-haryy
