Cheap motherboard and cpu combo
Foz2001
What would be a good combo to get from this site www.tigerdirect.ca. I already have 2X sticks of 512mb ddr memory. The computer is strictly used for internet, word processing, etc. No gaming. Looking for cheap as in 200 bucks. It needs to have onboard video or suggest a cheap video card to go along with it. What would be my best options? Thanks
ALSO will ddr memory work in DDR2 motherboard slots? im pretty sure the memory is PC3200.
$200 is pretty decent for a non-gaming build. any other apps that would be cpu intensive that this build might be used for? is upgradability important?
Since you have DDR, I'd go for the Asrock board if you want intel. This is also upgradable to a quadcore or core2duo. You could also get a single core P4 or Celeron instead of the Pentium D dual core. Shop around for the best price.
$79 - AsRock 4CoreDual-VSTA LGA 775 VIA PT880 Ultra
$112 - Intel Pentium D 820, 2.8GHz, EM64T XD Dual Core, 2X1MB, Socket LGA775 (Retail Box)
If you want AMD, you'll need to go socket 939. Though, you'll have to decide between single core or dual core, and between the 6100 or 6150 chipset. The 6150 is better for video playback.
$90 - Foxconn 6150K8MA-8EKRS mATX S939 GeForce 6150
$73 - Foxconn 6100K8MA-RS Socket939/GeForce 6100
$80 - AMD Athlon 64 3200+ 2.0Ghz
$133 - AMD Athlon 64 X2 3800+ 2.0GHz
