Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Word of warning... don't buy RGB LEDs from them. I bought 50, about 5 of them had a defective die (either blue or green in my cases) and the water clear lenses are crappy. If you have a choice, buy ones with diffused (milky) lenses instead of clear. There are different viewing angles for each of the colors. This is a characteristic of clear lenses and is present in EVERY water-clear RGB LED sold. Because of the physics of lenses, differing projections are unavoidable. When placing a light source behind a convex lens (such as the dome of a LED), any position displaced from the exact center will lead to a change in the displacement of the projection. You may see that this with single-die LEDs, but it is more apparent (and unavoidable) with multi-die LEDs. I say avoid them if you can.
I'm still looking for cheap diffused RGB LEDs... If anyone can point me in a good direction, please let me know!
cool.. I bought about 25 UV Led's from some guy on E-bay for about 5 bucks. He even through in a resistor for 1 cent each. They are bright and good for many things.
