I don't know if anyone has ever done this or even talked about it (damn the dead search function!), but has anyone ever thought about using a automotive fuel pump as a water pump?
Most automotive pumps are fairly quiet, and only get noisy as they start to go. They are designed to run for hours upon hours upon hours. They are natively +12V, so an easy install. They're normally submerged in the tank (stock ones at least), so as long as your fluid isn't conductive, you can do the same and use the fluid to insulate as well. And best of all, they're plenty cheap when you've replaced the stock one in your vehicle with a higher flowing unit. They have outlets for 5/16" hose (ID), so they're pretty easily adapted to/from. The only catch is that it has to be submerged or an adapter made in order for the pickup to work. Fuel is corrosive enough, so water should be perfectly fine running through there...
I know that my stock fuel pump runs 90lph, and I can get a very cheap stock pump that will run 130lph. Toyota Supra stock pumps flow around 255lph... from reading around, I have found that the Supra pump rates at 40gph at 26psi of pressure, so I can only imagine the flow at low pressures like watercooling systems end up having (what? 1-3psi?).
Perhaps this isn't enough flow? I'm not sure, but I am guessing that it should be just fine with a decent sized resivour and a radiator with several passes to it.
