cheap cpu cooler for x2 4050e
It should be sufficient. You might want to look into purchasing a stock cooler from one of the higher-end AM2/AM3 CPUs as well.
I think that you would get away with a passive cooler too. I use the Silverstone cooler inside my MiniITX build using a 5050e CPU and it does the job just fine.
do you think the mcr 220 is good enough for a passive on that or is the black ice any better?
