Cheap case with side intake?
While not exactly cheap by my standards (I'm a REALLY cheep bastid), and the side panel fan mounts aren't "like" that Lian Li's, The Coolermaster 590 is cheaper at about $90 shipped and has one side vent aimed at the vid card(s) and one aimed at the cpu. I'm pretty sure they both accept 80, 92, 120 or 140mm fans.
Then there's the 690 if you prefer top mounted audio/usb for $105 or so shipped. Seems to have the same side panel.
^This.
Also, if you want even cheaper, the Centurion 5 also has a side intake and is an excellent budget case.
