Cheap case w/ PSU recommendations
Pete84
I am looking to get ~2+ cases with cheapo PSU's for a bit of folding action, and so am looking for the cheapest case + psu combos out there.
I am able to get an ok ATX case with an Allied 350watt PSU for $34 at a local store. Newegg has combos that are cheaper but the shipping kills the deal.
Any tips? Thanks!! :)
If it's just folding with nothing fancy going on, I'd just get the cheapest combo at the local shop. $34 is better than you'll do online once you factor in shipping, most likely
Well I was hoping that perhaps there was an icredible cheap case out there . . . worth a shot.
Thanks anyhow!
http://www.chiefvalue.com/app/productdetails.asp?submit=property&item=11-195-014 << Just a HAIR cheaper, but if you like the case better there you go. That's not the cheapest one w/ a PSU either Course, the cheapest one is only like a buck cheaper and only has a 250 PSU.. but none the less it's cheap.
Personally.. I have never had problems w/ Chiefvalue. It never takes that long to get my stuff from them, and I'm in South Dakota.
Either way.. good luck w/ your folding comps. ;)
