G'day all,
I'm new to watercooling, this will be my first system (or rather set of systems) to have watercooling.
What do you guys recommend for cheap cases to start off with water cooling? I'm thinking something that can easily mount a MCR220 radiator, which also has space for a pump and a reservoir inside to keep everything neat and tidy. Would the best thing be something that has 2x120mm fan slots in the top to mount the radiator?
I'll be building a few of these machines for a number crunching cluster, so I dont want to have to mod the cases, it'd be nice for them to just bolt straight together.
I'm thinking Coolermaster 690 or 690 II, Fractal Design R2B, NZXT Hades, Xigmatek Utgard, Lian-Li PC-K60 or something similar. All of those cases can be had for $100-150 Australian, the most expensive being the Fractal at $149. Some sites/forums says some of them might need to be modded to fit a top mounted radiator, which I'd like to avoid.
Anyone got any experience with those cases? What do you suggest as a good "starter" case for water cooling in the same (or lower) price range as those cases that doesn't require any modding?
