cheap bolt thru cpu coolers?
jcmuse
i lost the plastic thingy for my ds3l so i'm looking to buy a bolt thru cpu cooler that doesn't require it. I need something on the cheap as well :)
edit: wait, will the bolt thru kit work with a freezer 7 ?
Not all that hard to make one yourself with nuts, spacers, screws, etc you have laying around (if your a good geek ;) ). This is what I did with the stock Intel mount after removing the push pins and a mounting bracket from an old Thermaltake cooler:
Otherwise, you can buy a Thermalright bolt mount from a lot of places. Get something like that and just remove the push pins from the Freezer 7 and use the back mounting plate from the Thermalright kit. Or something like that.
i actually have the bolt through kit already. im giving my mobo to my mom but i want to keep the true that is on it now for myself.
if i can use the bolt thru kit with the freezer 7 then i'll be all set:)
