Cheap air compressor/blower
Dra
Can someone recommend a cheap air comppressor/blower for cleaning out my computer? I absolutely hate buying the canned co2 because they tend to be quite expensive and don't last long.
Look at the date of this post... I'm surprised no one answered you. I'm looking for a good air compressor too as I'm tired of buying cans of air. If you guys can recommend a good one that has a filter for water and is oilless I would appreciate it. Thanks in advance.
After digging through the forums a bit more I came across this line which is a nice summary of what to think about when looking for an air compressor:
"If you drain the tank after each use to prevent water buildup, have a decent in-line air filter ($20-$30) and keep the regulator under 75 psi, an air compressor is the fastest and most thorough method of getting the dust out of your machine. You won't flash-freeze any of your components, either."
