Cheap 3rd Party Ink Cartridges
cspos
I'm done with paying full price for ink. Where do you guys get your cheap cartridges? And by cheap, I mean in price, not in quality.
How does something like this look?
For the record, I have an Epson R200, so the new cartridges have to be compatible with the Epson T0481, T0482, T0483, T0484, T0485, and T0486.
Cheap ink isn't the way to go. It causes more problems than it solves. That's for sure. I am a printer tech and I can tell you that cheap ass ink refils and refurbished/remanufactured toner cartridges in the case of laser printers only causes premature hardware failures and other issues.
The aftermarket stuff is no where near as good as original OEM.
What about those ink refill kits that use a ceringe (spelling) frag?
~Adam
A new set of OEM cartridges costs more than the printer itself. I'm not worried about damage.
~Adam
Those aren't a good idea either. They claim that the ink is the same and it isn't. Also inkjet cartridges, regaurdless of brand were never designed to be re-filled. They are pressurized and tampering with them in any way can produce very bad results. I've even seen the cartridges just start leaking all over the inside of the printer. If the ink gets on the paper path, the printer is done for.
Yeah I can understand that. Good luck with that though. The idea isn't very sound.
