Cheap 2-PC tables?
damonposey
I'm looking for a -->cheap<-- table that can fit 2 PCs easily. I have 2 heavy crts so they can't be those plastic ones, because those make the table sag, then the keyboards aren't flush with the table, and its very annoying :D Anyone have any ideas?
Define cheap?
I know of a company that offers customized solution for multiple computers.
Try a google search for: Anthro
They are pretty expensive once you start customizing desks.
cheap being under $60. those anthro products are very neat, wish i had more $. but i just need a big flat table top and 4 legs, nothing fancy. If i can't find anything sturdy for that, i might just try and build one.
Same thing I'm doing. Two of those ikea tables side by side.
Works great:
