Cheap 2.0 Setup
LiQuId StEeL
My audio sucks, currently: Logitech x230... absolute garbage, but they were cheap [and I had a BB gift card for $40]. I'm sick of them, I've been sick of them since I got them, but oh well.
I don't like the sound of the usual suspects (Klipsch, Logitech) for computer audio, so I've decided to throw down a bit more money and get something that actually sounds good. Since I'm still in a dorm (and will be for the next five or six months), I'm not going to bother buying a sub at this point in time; I get bitched at by the RA's enough for these crappy x230's. I know it will sound less-than-stellar, but it can't be worse than these turds.
Budget: as low as possible, yet still retain some quality. I don't want something that is only good for audio and useless for if I buy a TV down the road. I'd like to keep it under 400, but obviously the lower the better.
Connections: I'll be hooking up my desktop (with Audigy2 ZS) and my laptop (Asus G1S) for inputs. I may bring my PS2, but that is irrelevant. Whatever reciever I get doesn't necessarily need to have video, but I would like to have the option to hook it up to a HDTV and have acceptable performance.
On to my thoughts...
for Reciever, I was initially thinking an Onkyo tx8222, but the lack of inputs sort of scared me off. Next I saw the Harmon Kardon AVR146, and it looks a lot better. For $200 HK has the refurbed (and BB has it on sale periodically, I saw) version. I like the input selection, and despite the HDMI not processing audio, it is a nice feature in my eyes. Unless I have overlooked some other option (or fatal flaw), I will probably pick this up.
Speaker options:
Cheap: Insignia 6.5in from BB. I've heard they are actually quite good, especially when the price is factored in.
Medium: Polk R150. Seems to be a normal recommendation for lower-end setups.
'High' (still cheap, I know): av123.com X Series - They seem to be the best option under $200, and a recommendation everywhere I look.
I'm not sure on the speakers. The cheap bastard inside me says to get the Insignia, but I really don't know. Would the difference between the three be significant enough to tell the difference [and justify the price difference]? I'm guessing yes, but I figured I'd check before I spend the money. I'm leaning towards the X series; buy the best [for the money] now, and not really worry about quality.
Whatever I get will be primarily used for music (links to artists and such), with movies as a close second (my current roomate is a tool, so I try and watch movies in other peoples' rooms rather than mine :p). I'll probably pick up some decent headphones sometime as well (Grado SR60 come to mind), but again, that seems irrelevant in the decision of what to get.
Any suggestions/input? Will the 2.0 be tolerable enough until I'm not in a dorm?
I suggest you to get at least 5.1 receiver if you would like to expand in the future. Stretch your budget a little bit if you can. You are getting into this audio stuff thats requires lots of expenses. I'm building similar setup and ordered X-LS from av123. I have no doubts that they are good bang for the money.
Also i bought those stands http://www.audioadvisor.com/prodinfo.asp?number=ENCST
