Aug 31, 2006 #1 A adorecm n00b Joined Aug 21, 2006 Messages 12 Does anyone know where to buy cheap 120mm/4.5inch hole saws with arbors? Or, conversely, does anyone know how to make a clean 120mm hole without spending a ton of money? (i.e. less than $15). Thanks!
Aug 31, 2006 #2 M morpheus6d9 [H]ard|Gawd Joined Mar 11, 2005 Messages 1,230 http://da.harborfreight.com/cpisearch/web/search.do?keyword=hole+saw&Submit=Go
Aug 31, 2006 #3 S SarverSystems Supreme [H]ardness Joined Feb 9, 2002 Messages 7,408 Make sure you don't buy drywall saws. They won't cut through metal.
Aug 31, 2006 #4 A adorecm n00b Joined Aug 21, 2006 Messages 12 SarverSystems said: Make sure you don't buy drywall saws. They won't cut through metal. Click to expand... I'll be cutting through wood.
Aug 31, 2006 #6 S SarverSystems Supreme [H]ardness Joined Feb 9, 2002 Messages 7,408 A drywall saw isn't gonna cut through wood very well. Remember, you get what you pay for. A good 5" holesaw with arbor is gonna cost ya about $50 or more.
Aug 31, 2006 #7 T ThirtySixBelow Gawd Joined Dec 4, 2004 Messages 846 Well, if 50 dollars is the going rate, then this one at 28 is a bargain. http://www.amazon.com/gp/product/B0007WK9P2/102-2478750-3036951?v=glance&n=228013 As an Amazon Associate, HardForum may earn from qualifying purchases.
Aug 31, 2006 #8 S SarverSystems Supreme [H]ardness Joined Feb 9, 2002 Messages 7,408 Good call. It still needs an arbor, and there is no way in hell that's gonna cut steel. MAYBE aluminum, but steel? The OP is using it for wood, so that one would work fine, as long as he remembers to buy an arbor to go with it.
