changing screen size
Shawnzzzy
hi,
I have a Toshiba Laptop with a 17" screen and was wonding if it was possible to toggle the display software to only use 15" of the screen because i have some programs/games that cant be set to the 1400 x 1200 or whatever that resolution is. And those programs get too distorted on the full 17".
I would appreciate any ideas on the isue.
shawn
You should be able to run them in a window, solves it all for you. ;)
BillR
