Changing RAM/FSB memory frequency and ratios?
AcidicRage
I just downloaded the program, CPU-Z, and it shows that I have a memory frequency of 141.6MHz and FSB:DDR ratio of 3:4. I was wondering if this is good or bad? I know the memory frequency may be high because I have overclocked the FSB in the BIOS.
Also....
CAS# Latency is 2.5 Clocks. RAS# to CAS# Delay is 3 Clocks. RAS# Precharge is 3 Clocks & Cycle Time (Tras) is 6 Clocks. Everything look good?
Btw, I have two sticks of Mushkin 512 PC2100 DDR.
I think its best to match the FSB and memory, so the ratio is same and is it the lower the better on all clocks? How do I change it? I believe that when I overclocked in the BIOS, there was an option that changed my overall multiplier (P4 = o/c to 2.12ghz = 100x20, mine is now 106x20) which I think changes the MEMORY and CPU Mhz...how do I make the ratios same?
raise your fsb up to match that of pc2100 (133mhz) your running it at 100 mhz, then back down on the multi. you could also overclock.
Ok got it. I found where the options are in my BIOS, they were in the Advanced Chipset Features. I can set all the CAS# latency stuff from 2.5 to 2.0 and all the precharge. If I do change these, it gives me a warning on the side that changing the timings and settings can cause my computer not to reboot up, in that case I have to reset/clear the CMOS. How would I go about just in case?
Some mobo's will automatically reset to default values if you get too aggressive with the settings ( it will try to boot, fail, and then reboot to default ).
If yours fails to boot and doesn't reboot, just turn it off and pull the CMOS battery from the mobo for about 5 minutes. When you put the battery back in and boot up, the BIOS should be back to default values.
OK, I managed to change the CAS# Latency from 2.5 to 2.0. It didn't hang up on me or anything ... any other timing settings I should change like the RAS#, etc while I'm still in the BIOS? I hope this would help improve my performance a tiny bit.... :)
