I'm having an issue trying to find the max FSB that my system can handle due to Windows not recognizing the change after lowering the default multi from 10x to any other value. I've disabled every power savings option there is that is located in the BIOS but Vista64 seems to have issues with seeing any change. Leaving the multi alone lets me overclock without issues but I would like to test out performance on my system with a 1:1 memory ratio but can't due to this issue.
For instance, I can change the multi to 6 and up the FSB to 400 but no change in Windows occurs and I can't figure it out. It seems like I'm the only one who has experienced this as I haven't been able to find anyone with a similar problem. I'm sure its something simple.
