Changing motherboard - Help
I have to get my computer's motherboard changed this week. I want to know that the operating system (Windows XP genuine) which I had in my old motherboard can be reused in my new motherboard also. Won't it be stopped working after downloading any Microsoft software or getting updates of Windows from the Internet? :confused: Please help, I don't wanna spend more bucks on another operating system! :(
Waiting for your answer!
__________________________________________________________________________________________________________________________
How To Change MAC Address with SpeedDemon
should work ive never had a issue and i swaped on oem versions of xp
Also time to upgrade buddy unless your sticking with the old processor generations :(
Will work fine, the copy protection may fire and ask you to validate your copy.
If you have to validate your copy, just follow the on screen guides.
