Changing Memory Bus Mode
lovelyx
Hi!
I just installed nTune, and it says that my current memory bus mode is 64-bit, but it has capability for 128-bit.
It recommends "upgrading memory DIMM according to system manual can greatly boost system performance"
The problem is that I don't know exactly what it means.
Any help?
Thanks in advance.
More information is necessary to help you out. Send it would you?? :rolleyes:
Most likely what your problem is that you have a dual channel system with one stick of RAM installed. Thus you are restricted to a single 64bit channel instead of two 64bit channels with two sticks of RAM.
