Changing BIOS...is it possible? (Note not Upgrading... but Changing)
abudhu
I upgraded my Dads 8000 Inspiron to Win XP the other day, and the incredibly OLD Dell Bios annoys the (Insert curse word of choice here) out of me. Its so uncapable of doing anything advanced. I know I could update to DELLS newer bios but I simply have an outstanding hatred for pre-built systems. :)
So, is it possibly to totally flash the BIOS to a different brand? So could I change the BIOS from Dells pile o' crap to say...Awards (Or whoever's) Bios? Or would it simply be uncompatible because of the mobo?
Just a thought, because there is currently nothing on it really besides XP/Office 2003 and some files that can be backed up in a flash. + It would be an interesting little side activity for a boring weekened and such.
generally, this is a no. there a few notable exceptions (like OpenBIOS). but, from an engineering standpoint, the bios is designed and customized on the hardware level to work with *that* board and cannot be swapped out like other software.
this is espescially true on OEM boxers like Dells. i don't know if Dell PCs use actual dell-designed BIOSes or if they are just customized versions of other BIOSes.
At any rate, getting the BIOS update utility to even write a non-Dell BIOS image to the CMOS would be a real fight since it probably does version and hardware checkign to make sure that something dumb isn't done.
abudhu said:
I upgraded my Dads 8200 Inspiron to Win XP the other day, and the incredibly OLD Dell Bios annoys the (Insert curse word of choice here) out of me. Its so uncapable of doing anything advanced. I know I could update to DELLS newer bios but I simply have an outstanding hatred for pre-built systems. :)
I'd assume no, I'd think it would be risky at best between even two very similar boards, i.e. let's say flashing a K8N Neo 2 with a K8N Neo 4 Ultra's BIOS. Having said that, I did flash my K8N Neo 4 Platinum SLI with a K8N Diamond's beta BIOS...but it's known that they are the same board except for one fan on the MOSFET heatsink on he Diamond, and the motherboard package.
I always did think that even Dell is let's say subcontracting out to Foxconn that the boards are pretty propitarty, and thus there isn't an equivelent by the same company that the public can buy, except maybe from Dell directly as a replacement part.
That and well, WHICH Award BIOS do you pick? Just grab one from a board that looks about right and go for it? I never looked but does Award's site actually have a generic BIOS that one can pull down and flash a board with, just to see if it works?
But hey...if you don't mind playing guinea pig, have fun. I would be seriously curious to see what happens if you do try this stunt...but I suspect the board will either just not POST, or won't even let you try to flash it. Good luck if you do.
Haha,
Damn. Alright, well I guess I'll just try updating it sometime.
Quick question before I go: Since I am BIOS Updating Retarded. Updating BIOS = Don't lose Info on HD correct?
that's correct. the BIOS affects nothing except the motherboard's firmware. your data on disk is 100% safe.
abudhu said:
Haha,
Won't do a thing to the hard drive. Most that might happen, if Dell has you set a parameter to clear the CMOS with whatever program they use to do the BIOS flash (or if you do it manually) is that it might not see the hard drive, if it's on some port that isn't active by default. Even that I wouldn't really expect...Dell knows that they will be dealing with people who have never flashed a BIOS before....and very generally any IDE or SATA port is active by default, at least from what I've seen.
Dude!
I hate dell :)
BIOS A21
Ran CPU-Z: CPU: 668MHZ. I was like "My Dad bought a 1ghz computer"
Checked Windows Device Manager: 668MHZ
Checked A21 BIOS 700MHZ CPU.
I SWORE my dad bought a 1ghz computer back when he bought this.
Updated BIOS to A23
CPUZ: 998MHZ
Windows: 998MHZ
BIOS: 1GHZ
Geez. Maybe thats why it was running REALLY slow on Win2K all that time ago. Score 1 for dell!
abudhu said:
Dude!
I hate dell :)
BIOS A21
Updated BIOS to A23
CPUZ: 998MHZ
Windows: 998MHZ
BIOS: 1GHZ
oh suxors!!!
abudhu said:
Dude!
I hate dell :)
BIOS A21
Updated BIOS to A23
CPUZ: 998MHZ
Windows: 998MHZ
BIOS: 1GHZ
Not the first time i've seen that happen.
incidentally, over the past christmas, i did some tweaking on my mom's computer (an HP Brio).
It had a slot-1 P-II 400Mhz in it, but reading the documentation i saw that it supported clock frequencies as high as 700Mhz. I just so happened to have a P-III 700 with me and decided to install it and give it a whirl. Upon first boot after installing it, the BIOS identified it as "Intel Not-Yet-Named-CPU at 450Mhz". a few minutes on the web and i had a BIOS update. After the update, it properly identified the CPU and also clocked it at the correct speed.
abudhu said:
I upgraded my Dads 8200 Inspiron to Win XP the other day...
Inspiron 8100=Pentium3 (Since you said 668MHz & 1GHz, I'm presuming you mean P3. The Inspiron 8200 is Pentium4, which started at 1.4GHz.)
Inspiron=Laptop=Mobile CPU
Pentium3+Mobile CPU=Speedstep=CPU that is identified as capable of running two speeds- say, 700MHz & 1GHz
You (or your BIOS) most likely had the laptop set to run in battery/power-saving mode at all times, and the new BIOS probably cleared that setting.
A different story is that a P3M 1GHz is supposed to default to 733MHz in battery mode, not 667- which it seems yours was doing.
My bad, I put the wrong model # to start. Its a 8000, not 8200. Sorry for the mixup. But I was running of the UPS. No matter, it registers right now :)
But thanks for the info all the same.
abudhu said:
Haha,
OK, now if you don't know the answer to this question, you really shouldn't even be considering attempting this project.
Secondly, Dell used to use all Intel boards so it was possible to flash the Intel BIOSes into the Dell mobos, but Intel doesn't provide much more than Dell does anyway.
Actually Dell and HP and many of the other computer manufactures use various different manufactures for their products. I have seen Everything from Asus to MSI to ABIT to on and on. In fact their are a portion of them built by other companies that most have never heard of. In fact one of them is here in my home town area. Its a company Called Celestica. They manufacture Mobos for many of the different PC manufactures Dell included. Ive toured the place and really cool stuff. You have to wear some antistatic clothing/shoes and straps. Big ass wave solder machine was pretty cool looking to. But the chances are that prolly not going to be able to make the bios something its not.
I was being sarcastic. But I just wanted to make sure. Sorry for wanting to double check my knowledge. :(
I'm telling ya, if you're really serious about this check out the Mr BIOS site I posted. I got a replacement BIOS from them a few years back for an old HP system and it ran great.
I'm sorry; I didn't mean to offend you. But I have seen many a BIOS flash (even BIOSes designed for their boards) go bad by people that didn't know what they were doing.
The other thing you have to consider here is: Is it ok for this system to become a paperweight? If you try to put something in that doesn't work, the mobo probably will be shot (unless it has a socketed BIOS and even then hot flashing is no given).
And MrBIOS is a great site and they do nice work, but is $60 for a BIOS for this computer worth it? What more would you get from the BIOS? Maybe the ability to manually change CAS latencies and the ability to use HDs above 120gig. I can't justify this cost when you can get a new mobo/CPU combo for around $100 (although with a dell, you would need a new case and PS as well, so maybe total cost would be about $130).
wait, this is a laptop. Now I feel really stupid. No laptop I have ever seen offers any sort of fun tweaks in the BIOS (maybe Alienware or Sager, but I even doubt that).
Wait, you're right! I'd still try it though :)
Oh, Alienware laptops do offer a lot of tweaks in their BIOS...
Well I updated the BIOS to A23 like I said, so there is no need for a different manufacturer BIOS. But i was still pretty curious :)
Mr. Bios thing seems like a cool utility. Might play with it just for the sake of playing with it.
