I had my voltage settings set to auto since building my system(exception is enabling XMP). According to HWmonitor the Vcore would vary from .804 at Idle to 1.344v running something like Prime95. Temps would be 20c at idle and 67c max after running prime95 for about 10 minutes.
I started messing with the vcore, going with 1.275v in BIOS.
While testing temps dropped to about 54c after about 10 minutes of Prime95. Other testing apps give similar temperatures.
What is werid is Vcore no longer goes back to .8v at Idle but is reported as 1.236v. The CPU frequency does decrease to 800mhz during Idle. When stressed Vcore shows 1.176(vdroop?). The VID does go down at Idle and shows 1.363v when stressed. This is according to HWmonitor.
Before I did this I saved my previous profile and loaded it back up. Going back to the old auto settings does not bring back the old results.
Was something glitched with the auto setting and changing it "fixed" it? Is the Vcore not decreasing intentional?
I am really confused about these results.
