HaMMerHeD
- Jul 13, 2004
Today, I upgraded my motherboard, CPU, and memory. I went from an ASUS A8N-SLI with an AMD Athlon 64 x2 4800+, and 2 GB of Corsair DDR-400 to a Gigabyte GA-P35-DS3R with an Intel Core 2 Duo E6750 and 4 GB of Mushkin DDR2-800.
I have an Enermax Galaxy DXX 1000 W power supply.
When I had the AMD hardware installed, I heard no beeps and the status light on the back of the PSU was green. After I installed the Intel hardware, I began hearing two quick beeps every 3 seconds, and the status light changed to red. Apart from those two conditions, the computer is operating normally.
Looking through the Galaxy's user's manual, I came across the following 2 options for this error-condition information:
A) Power Good (PG) Signal Abnormal
B) System loading lower than PSU minimum output requirement
The minimum output requirement is 50 W, and since this computer is using about 200 W sitting here, I think it is safe to deduce that option B does not apply here.
So looking at option A, I am no further to answering this question. Why would this condition change after installing new hardware, unless the PSU was somehow damaged during the upgrade?
Any thoughts?
Any thoughts?
