My HD is divided into two partitions, when I did a re-installation of XP I deleted the primary and re-created it into two parts.
However, when I did this XP made my old partition which was the secondary the main and called it C:\ so when I installed XP on the new partition XP called it D:\ and put Windows there.
Is there anyway to change the Windows installation directory to C:\ easily?
If not, when I do a re-installation again how can I "force" it to install in C:\ because the Windows partition program thing seems to automatically stick any active partition as the first drive letter.
