Change circuits in a house?
saan44
I'm not sure if this is the right place to put this question, but I didn't know what else would be more appropriate.
This may be a stupid question as I know virtually nothing about electrical systems, but is there any way to switch a circuit that an outlet is on?
I just moved and in my new place, the kitchen and my computer room are on the same circuit. I've tripped the breaker a couple of times now with the fridge, microwave, washer, and dryer all on the same circuit as my computer, two monitors, and assorted other smaller items (speakers, modem, router, etc). It's usually not an issue, but occasionally I'll forget and throw something in the microwave and *poof*.
Essentially, if there's an easy way to swap that outlet to another circuit that isn't used as much like the bedroom or something that would be fantastic. I doubt it's possible from what little I do know about electrical stuff, but figured it would be worth asking in case it is.
An electrician is going to be required for this because it sounds like you need to create a new branch at the breaker box. While you might be able to have the computer room portion attached to another existing branch like the bedroom, there are power formulas and code requirements to consider
Not that it would be impossible to do if you knew how, but I'm fairly certain most states require a licensed person to do that kind of work.
edit -
You did not specify if you own or rent, but if you are renting you don't want to be liable for any damages or fire and should discuss this with your landlard.
If you live in a student housing apartment complex or something of the like, you might be able to get away with having them hire an electrician to do it for you, for free. It makes no sense to have the kitchen and computer room on the same circuit, especially if you have all of those appliances on the same circuit. It is a poor design, and they are responsible for having it set up that way. Are you so sure about the dryer being on the same circuit as the other appliances, though? Usually those have their own 240V dedicated circuit if I am not mistaken.
Either way, get an electrician to do the work. Even as an Electrical Engineer with (soon) a 4-year degree, I would hire an electrician to do any major work. Being a EE doesn't make you an electrician. Hell, I even currently work in the power design sector - there is just so much to know in terms of codes and documentation on the electrician's side. The last thing you want is to be liable if anything goes wrong, or worse, you severely hurt or kill yourself.
Thanks guys. This is pretty much the answer I was expecting, even though it's not the one I wanted to hear.
For the record, I rent and the place was listed as a two bedroom so I use the significantly smaller room for my computer stuff since my fiancee and I live together. My landlord is pretty good about getting stuff done so I'll have to ask him if he'd cover this or not.
Codes.. blah blah blah. House wiring is pretty standard stuff, not rocket science. Most stuff people do is by code even when they have no idea what they're doing. Residential wiring has been around for a hundred years or so if not more, so it can't be rocket science. ;)
Just takes a bit of DIY Electrical reading to be able to pull it off safely and easily... just don't forget to turn off the main breaker when you try it.
That being said, a new line will have to be run from the bedroom (or kitchen, or just the washer/dryer) to the breaker box. Doing this could be extensive depending on how the apartment/house is built and where the breaker box is. If there's an open basement then it's easy, but if you have to fish through a bunch of walls and ceilings then it can get more difficult and may require more than just electrical knowledge (like maybe a bit of drywall patching knowledge)...
This leaves you with the options of either talking your landlord into doing it, getting your landlords permission to have it done and hiring and electrician yourself, or doing a bit of reading and hopefully getting a friend with more experience to help you out.
Again, if you wanted to do it, it could be done without extensive knowledge... but with the work it could potentially require, you probably wouldn't want to try it.
Get a UPS for computer so when the breaker trips you can run and flip it back on before you lose all your stuff.
Haha all these seems like so much work. Just run an extension cord from your bedroom to your computer :D if you really wanted to get all fancy I was at the hardware store the other day and saw these neat flat extension cords designed to run under carpet. Simplest way to do it in my opinion and if you are renting then it doesn't matter because it's not permanent.
The codes are there for everyone's safety. Yes, they can be a pain in the ass at times, but the last thing you want is a lawsuit on your hands. Even if he gets the OK to do it himself by the landlord, if something goes wrong and it causes a problem (i.e. starts a fire and burns down a building) then he would be partially liable, if not completely.
The moment you start tinkering with electrical wiring, you "own it" and are required by law (at least here in FL) to update the entire system up-to-code. Yeah, this mainly matters for business environments, but since he is renting from a landlord it is important.
Sure, this might be a simple job that can be done without extensive knowledge. Then again, it might not; it is impossible to assess without looking at the design drawings for the building's layout, electrical power plan, and taking a walkthrough. I'm not trying to discourage you, but just want to give a heads up.
A long extension cord running under a rug or something of the like would probably work just fine. Just get the correct AWG for the given distance and current you will be drawing through it - this is important, especially if you run a 1 kW+ PSU.
Good luck!
I agree with the others, the simplest/cheapest way is to run an extension cord from another room circuit to the computer. That probably would be a #14 ga, 50 foot extension cord. These are usually sold for drills/single machine use for work places. Find at Lowe's/Home Depot/Harbor Freight etc type stores. Add a surge protector and you should be good to go. That cord/surge combo should handle the box, monitor, printer, and a scanner. Any other peripherals I would try on the existing wall circuits. Switch off your existing circuit at the breaker box and with an outlet tester find the live circuits in other close rooms. Don't use the GFI plug in the bathroom.
While using the cord, feel the wire to see if it is getting hot. If it's really warn to hot you will need to reduce the load on that circuit by adding an additional extension cord and surge protector from a different outlet/circuit. Then split the high energy using devices between the two cords. I would route the extension cord(s) along the baseboard and through the hinge side of any doors. If you have to cross a traffic pattern, like crossing halls, go under the carpet for safety. Don't make sharp bends in the cord. Sharp bends (90* or less) create hot spots and will eventually fry the wire at that spot. Think fire if that happens. Gentle curves are the way to go.
I wouldn't hard wire the outlet unless I owned the property.
