Alright - wondering if you guys could help me nail down a stability issue with this board - I'm not even sure if it is the board, but it's where I want to start since it's pissed me off already.
Just built a system for my brother a coupla days ago and here are the key components:
Chaintech VNF4/Ultra board
AMD64 3200+
1 GB (2X512) Corsair Value Select RAM
BFG 6600 GT OC
OCZ 520 Watt PS
I had problems with the firewire port and the network adapter. In fact, even after installing all of the drivers I still had network adapter issues and had to just throw in an old NIC card because I got tired of having DSL issues for like 3 hours and some weird error 769.
Got those resolved and everything seems to run fine. I dl'd folding@home and ran it for about 6 hours and it was fine. No hiccups and no stability problems - it ran fine.
But whenever it tries to load a new window (to play a video file; to show a zoomed image after clicking on the image) or make a change (change a bind in CS:S) the system freezes sometimes. I can't reason out why it does that. The CPU temperature doesn't spike and it doesn't seem to be a power issue.
Any thoughts where I could start or any way I can narrow down the issue? I've never come across this problem in a build - although I've only built about a half dozen systems so I'm still pretty new at this.
Any help is appreciated. Thanks in advance.
EDIT: It just froze on me during Call of Duty and when I tried to get back in the game, CoD wanted to start in safe mode, but I figured that was normal.
I still don't think it's a gfx card issue, tho -
AMD64 3200+
BFG 6600 GT OC
OCZ 520 Watt PS
