Which will be easier to set up for a noobie computer builder? They both overclock pretty well although the Dfi does a much better job of it. I plan on sticking in a Sempron and taking it as far as I can...
Well, you say you're a noob PC builder, but then you want to O/C as much as you can... DFI boards are notoriously tough to setup for noobs because of all the BIOS tweaking/options. I had the VNF3-250 board for a year and it worked very well. It overclocked a little bit, but I didn't push it very hard. You'll be very happy with the inexpensive Chaintech.
i got one back when they were on sale for $47 and got a $50 retail 90nm sempron retail.
anyways super easy set up--not pickey about ram--has native sata , not pickey about ram
just a super easy build . and it has some overclocking features --v-core v-dimm, memory divisors --settings --just like the expensive MB's and get this-- it is the only mb i've got in years that came with the latest bios and didn't need a bios update--
and the MB has good quality--just a kind of basic retail package .
my only gripe is the bios has no fsb above 250 --but this sempron 90nm can pull all the way to 250fsb with ease .
not bad for a $118 ratail cpu and MB-- you should give it a look .
you might find a package deal somewhere on sale-- yes it is PCI express --but with the $$$ you save you can put that twards a good pci-e videocard.
