Chaintech SKT600 (SEMPRON) BIOS
Bustercaps
Trying to flash the BIOS (PHEONIXBIOS)
but it says that there cant be any MEMORY MANAGERS running
Well I tried to use a BIOS boot disk from Bootdisk.com and it doesnt work
I need to update the BIOS for a new SEMPRON CPU.
Anybody got any way to creat a Floppy with out any memory managers on it...
Thanks for any feedback
Buster
I don't have the same exact mobo, so I have no idea whether or not this will help, but I do have one of the same brand. On my VNF3-250, I couldn't use my floppy drive from WinXP for whatever reason, but I could still boot from it. I copied the bios file onto it, rebooted my comp, and hit Alt-F2 to bring up the built-in BIOS flash utility. Once I did that, the program auto-expanded and gave me a couple prompts, then flashed perfectly fine. Don't know if that's the case for your BIOS, but hope it helps.
