Chaintech AV-710 v MAudio Rev 7.1
The Chosen One
Hi guys, i need a sound card for my new HTPC, and im trying to decide between the Chaintech AV-710 and the M-Audio Revolutions 7.1. At the moment, im just running a SB Live! into my Onkyo TX-SR601E with 6.1 Jensen speaker setup via SPDIF. Due to limitations im told are inherent in the SB Live, i only get sound out of my Front L/R speakers (not centre or rears etc). So im looking to upgrade to one of the two cards mentioned above.
Im in Australia, so im going to be paying $90AUD for the Chaintech and $190AUD for the MAudio.
I use the HTPC for DVDs, HDTV, MP3s and CDs, so i need sound thru all my speakers (where supported) hehe. I assume that with the Chaintech, i just run an Optical Digital Output to the OD Input on my amp, and with the MAudio, i use a Coax Dig connection; and that both of these will then give me the full 5/6/7.1 or whatever thru that digital output? Cos as i said, atm im using a Coax Digital Output from teh SBLive but im only getting 2ch.
So with that in mind, and the fact that i only want the AMP to do the sound processing, which sound card do you guys think i should get. Bearing in mind to that the MAudio costs $100AUD more (is it worth the extra?).
Another thing, is the SQ via SPDIF likely to be any different between the two?
hmm i wonder if i can wait till i come to the US in December and save about $45 hehe.
Thanks in advance guys.
You won't get more than 2 channels out of the spdif of either card. If you want true 5.1/6.1/7.1 you need to use the analog connections.
I feel that the best digital surround support is present in NForce 2 MB's with sound storm. The sound is fantastic, and now that the next generation of CPU's has arrived, the price is teh sweet. I would say that that is your best bet, unless you have already purchased your other components.
Nah all other components bought unfortunately.
Psycho, are you sure about not getting any more than 2ch out of digital output? Ive heard different, and that seems pretty ridiculous, to only do 2ch digital. Also, i hooked up my fronts and rears (no centres) to my amp via SPDIF from the Live! just now, and with a bit of tweaking, got sound on all speakers, so surely those two cards would have at least that level of multispeaker implementation.
Why wouldn't he be able to get multi channel via spdif,? the spdif connection on the both the chaintech and maudio pass through the AC3 signal encoded on DVDs. And on the creative SBlive card, all he needs to do is to uncheck the AC-3 decode option in the creative control panel. As far as other materials, he can use prologic2 SRS or any other matrix surround that his receiver supports.
No contest. Get the Revo. The Chaintech is a nice bang/buck 2-channel card, but it's not can't do multichannel HT like the Revo can.
Dont use digital. Use analog. Hook up the 3 minijack inputs to the multichannel RCA inputs on your receiver. Cables of this sort should be easy to find.
I dont want to use analog, as i dont want the soundcard to do any processing as it is not going to be be as good as the amp doing it.
Don't be so sure that the reciever's processing will be superior to the soundcard's. Don't use the Live to judge the Revo. They are light-years apart in quality.
I agree with you, if your pre-pro is of good quality, then use that. Save yourself some cash and get the chaintech since you are using a digital output. I've owned both, and I'm currently using the revo, both these cards are pretty much indistinguishable using spdif.
Maybe you missed it when the other members told you that you will not get multichannel audio via the SPDIF interface unless that material is already encoded in a Dolby Digital format.
In other words you are not going to fix the "problem" you are having by replacing your soundcard with anything but a soundstorm equipped motherboard.
Not really.
Mr. X, isn't pro-logic or pro-logic2 considered multi-channel audio? I agree its not discrete multi-channel but it is a surround format that's available via spdif or analog.
That depends on your definition I suppose.
And more importantly if you can stand it ... cause to me Prologic sounds like crap. Especially with music. ;)
I was using prologic-2 for games, and it was more than adequate and convincing for that purpose IMO. and I listen to most music in 2 channel. With the exception of SACD and DVD-A, I see no purpose to recommend an analog connection over digital. Not debating, just stating my opinion. But saying that multichannel audio isn't available over spdif for games isn't exactly correct.
You're right. There's Soundstorm on the nForce and nForce 2. They are able to encode multichannel audio information from games (and other audio sources) and encode them to DD in real time. Soundstorm is extinct because not many people used it enough to care to pay extra for it.
Other than the (now outdated and irrelevant) nForce solutions, Mister X was exactly correct.
Pro Logic 2 and Pro Logic 2 are nothing but matrixing algorithms for turning two-channel audio into multichannel. I'd be willing to bet that you were listening to 2-channel audio, encoded to PCM format, sent via spdif, and then matrixed out to multichannel using a DSP algorithm. The Revo driver has support for Circle Surround 2, one of the better matrixing algoritms that I've heard. I like it much better than PL 2. YMMV.
GodsMadClown said:
I'd be willing to bet that you were listening to 2-channel audio, encoded to PCM format, sent via spdif, and then matrixed out to multichannel using a DSP algorithm. YMMV.
GMC, I wouldn't take that bet because that is exactly what I was doing and exactly what I said earlier. For gaming it is not 5.1 discrete, its an algorithm, just like EAX is an algorithm. But its STILL multichannel sound multichannel sound, it DOES work over spdif, and it's fine for gaming IMO. The nforce solution encodes DD where it never existed, most games are not encoded DD sound, so whats all the fuss about playing them in DD?. As far as music is concerned analog connections are only required for DVDA and SACD. I never suggested using PL2 for music.
I respect Mr. X depth of knowledge on this subject matter, as well as your own, and I repeat I wasn't trying to start anything. But there is a misconception that DD5.1 is the ONLY way to get multi channel sound. It simply isn't.
It is correct..... you know why?
Because the card is still only sending two channels of uncompressed audio and the receiver is doing the rest. :p
i have an audiocard in my HTPC that states "digital passthrough" which means that it does not decode the signal when it recives it(in the presence of a digital connection and digital source), it simply passes it through the digital connection to the reciver. now, with a 2ch source, a reciver would do the exact same soundstorm would do, just upmix it to 5.1 channels. just becuase soundstorm sends it as a digital signal to be decoded doesnt mean its doing anything that prologic II/ IIx couldnt do.
would these two cards not passthrough? if not, why the hell not?
the card is a maya MK-II gold, btw
prologic did, yeah.. but prologic IIx sounds awesome imo
I agree here, and the same applies for the encoded AC3 signal. In the orginal post, the poster mentioned that he wants to use his amp's (asumming he meant preamp processor, or receiver) digital input. He wanted sound from all his speakers, not just the front L&R, he was told that the only way to accomplish that was via analog. This is not so. For all we know, the poster intends to send the signal to a high performance processor such as a Proceed, Lexicon, Rotel, B&K ect... He must have a reason to want to do this.
BTW DD 5.1 does not always create a believable 3D enviorment in every situation. Just pay attention to the opening night club scene in Indiana Jones, Temple of Doom, and you'll know what I mean. This scene sounds a whole lot better in ProLogic2 than it does in DD5.1 IMHO.
hehe, thanks for the input guys its quite enlightening.
However i feel i should clarify what im using it for. Its going to be music, which is basically stereo most of the time, so i assume thats just going to get upmixed by the receiver or whatever, but if not, im not really that concerned cos its music.
2nd is DVDs, which are going to be practically always encoded in either AC3, DTS or whatever so this will be making use of 5.1ch, which means that using a digital passthru i will get 5.1ch correct?
3rd is for HDTV (and i suppose some SD also) which has AC3 sound most of the time, so that also will be multichannel via the passthru correct?
hehe im a little confused by the "yes it is, no it isnt" arguments. but i assume some people are just on different pages, with some talking about true multichannel as opposed to alogrithms or upmixing or whatever; and others just saying that if its coming out of all speakers, then its multichannel. hehehe
Atm, im leaning towards the chaintech, but then considering buying an MAudio when i come to the US next so that way it wont matter a great deal whether i use digital or analog.
