Chaintech 939 Nforce4 PCI-E
Quintis
I was planning on getting a Neo2 Platinum for about $140, sckt 939,
Then I stumbled upon the Chaintech VNF4/Ultra (sorry I cant post links, on library computer 'reason Im buying components'. Apparently it has an Nforce4 Ultra chipset, a PCI-E x16 slot, etc etc.
For about $129. Is this a better buy?
If it wasn't Chaintech, then I'd say maybe. I've had really bad luck with Chaintech, I ended up having to RMA one Chaintech board for a customer (I build systems on the side), and my dad burned through 3 RMA's of one of their Socket 754 boards before he just demanded his money back. He even won a Chaintech board in a contest, and it was crappy, if I remember right the one he won in the contest actually had empty socket holes...I.E. the holes where the CPU pins went had nothing in them to make contact with the CPU pins in some of the holes.
Having said that, a lot of people are real Chaintech !!!!!!s, so maybe between me and my dad, we just had really bad luck. They were all AMD 64 boards though, albeit Socket 754's.
I guess one way to look is hit a couple forums that have specific Chaintech areas and look for complaints. www.pcper.com at least used to be good for this, probably still is.
I've had pretty good luck with my socket 754 Chaintech board. I would say its a great deal.
