i have a couple of problems with this mobo first i have a geforce fx5200 wich i use but i can't disable the old integrated display driver complety so it uses for no reason system memory.so basicly its on but i have just lower the mount of memory wich it uses on bios.so if someone would know how could i disable it.
Secondly i have tried to install a sb live 1024 card but its just dont work i have tried to disable the intergrated sound chip but no mater what i do i just cannot install the card in to my system.
windows98 allways finds the card but when i install the software
i get a error message and the card dont work.So is the problem with the card,my mobo or my computer skills?
