CF Recovery help
cancersticks
Does anyone have any good recommendations for a Compact Flash recovery program? Cost, if under $100, doesn't matter....need to recover some VERY important photos from a corporate meeting.
Thanks in advance.
I used a free program from a German or Dutch company that worked great. Unfortunately I can't find it now. I'll keep googling for it.
Thanks for the recommendation! It worked great. I was able to recover about 95% of the pictures I needed to get at, even after the photographer (stupid) kept using it after noticing the original files were missing. (It also pulled up files from quite some time ago, that he had previously deleted from the card.)
Cool - glad it worked. Did you have to use the "deep scan" or the regular method?
