Ceton Quad Tuner - Delayed
I'm using a 2TB Western Digital Black drive... No problems with 4 streams. Tested with 3 recording shows and one live TV show being streamed to my Extender.
Cool but what really matters is what CPU you have powering all of that?
Honestly, if a ten ATSC/QAM tuner system doesn't bog down a SATA 300 drive then I highly doubt a quad CC tuner would. That's why CPU matters most when it comes to extenders and recording.
Motherboard is an Asus P5G43T-M Pro. I am using the onboard video for it.
It's running an Intel Q6600 (2.4ghz Quad Core) w/ 4GB of DDR3-1600.
It's a reasonably fast PC, though it's a 3 year old processor.
Testing it as I type this, I am recording 4 HD shows right now, I am streaming a pre-recorded show to my Extender, and I have Remote Desktop connection to my media center PC running Outlook and playing a 720p YouTube video.
I'm running between 22 and 30% of CPU usage and 2.36 GB of RAM. It runs between 6 and 9% with just the recording TV and streaming.
It looks like it's the Ceton card doing all the heavy lifting.
I use a single 1.5TB green drive. No issues recording 5 streams (Ceton + Hauppauge QAM) and playing back 2.
Cool, good to see a WD green can handle the task
Sounds like its doing hardware acceleration of the encoding process to help speed it all up
What encoding process? :rolleyes:
All it's doing is taking the incoming digital stream and throwing it too the harddrive (it's an MPEG2 stream). There is no encoding being done at all but there's still overhead for doing this, typically it's about 10% per video stream. Once you add in streaming that same content to an extender or two while also recording two or three shows it can add up.
what kind of hard drives are people who have it using? I'm curious about buffer and recording performance of 4 streams being written at once
Any hard drive will work for multiple streams going in and out.
If you want to work the math on it, figure 20mbit/sec (max HD rate) * 4 streams = 80mbit/sec. Divide by 8 to get 10 megabyte/sec, which just about any hard drive built since the late 90's can handle without choking....
decoding, overhead, whatever :eek: I mis-spoke.
I have a ceton card as well. Its very cool. Even my green 2TB seems like lightning fast compared to my old cable company DVR. You can just buzz through commericals with my new cheap MCE remote from Newegg. The UI being on a midrange PC instead of a dog DVR is now crazy quick.
The four tuners really seem to work. It's also very small..
The drivers worked for me perfectly - I had no real issues at all. I had to use two SDV (tuning adapters) which are a kludge (for two way communication - they are basically cable modems). But they work for me - they haven't "crashed" yet.
The worst issue for me is the cable company guy. I had to get a truck roll to get a cable card and the guy didn't think it would work and wanted to escape like his pants were on fire..
As i read on the Ceton thread over on other forums - some cable cards even brand new seem not to work. He put the first one in and I ran the Ceton diagnostics and it wasn't working.. So I finally persuaded the dude to switch and it worked right away.
The cable guy can also screw up entering the pairing info - but my guy didn't do that - thankfully. He wasnt' a bad cable guy - just not motivated and not trusting. If you get one of these do your homework - run the cable diagnostic and fully install the card before the cable guy arrives. Because don't expect much help from him..
Anyway the long wait actually paid off. And so far (knock on wood) being an early adopter hasn't cost me at all. This thing works. Also like crazy low CPU usage - I don't think I have seen it go above 10%. I have an i5-750 and a 5770 twinfrozr. So its not a crazy high powered setup. But I can still run some modern games on an HDTV. And now I can record cable tv and watch Hulu and stuff (my g/f loves that anime stuff - so I watch too much of that nonsense..haha)
How do you have two SDV Tuning Adaptors connected? Im imagining this in my mind and its not working.
You have the SDV TA hooked up in series?
Cable -->SDVTA1--->SDVTA2-->Ceton
I don't have any TA's as Comcast doesn't currently use them.
From what I have read at "the green button", what you do is:
Place a coax splitter first. One end direclty to the Ceton board, the other end to the TA(s).
You should be able to passthrough the two TA's, but you want the Ceton board to be on it's one direct feed.
This all depends on your TA as well. If you get the Cisco TA's, you'll need two, but if you get the motorolla TA, you only need one. Cisco supports 2 tuners while Motorolla 4.
This might actually work - but its advised against. Okay the deal with tuning adapters is they act like cable modems that communicate via some propietary protocol to the cable system. They don't like filter the stream. So while it has a pass through you don't need to use it.
So I used a splitter too feed the two Tuning adapters (the communicate back up the cable line) - each of those hook into your PC via USB. This way I have a stronger signal to send to the Ceton. Honestly passing through works fine but TIVO users seem to swear that a "crashed" Tuning adapter will block all cable shows. I found no indication of this but switched to the preferred set up anyway.
Ceton has asked the FCC to allow switched digital video requests via IP. Which would of course allow us to do away with tuning adapters (for most people). But until this happens you need tuning adapters as the cable card itself is one way.
Tivo has been *ucking up this shit for years now - and is pretty much responsible for the tuning adapter kludge. Internet protocol for the switched digital video requests makes 10x more sense. But most Ceton owners seem to feel PC's already deal with tuning adapters better then Tivo ever has. At least tuning adapters are free..
The cable guy was telling me how it took him 2 hours to do a Tivo install - it took about 15 minutes for me. And yeah I do need two tuning adapters because the Cisco ones were designed for Tivo people and only support two tuners at a time.
Ahh so you have the Coax Split 3 ways at the HTPC?!?!
1---> Ceton
2--->SDVTA--->HTPC
3--->SDVTA--->HTPC
^^^The SDV tuning adapters don't need the best signal quality - just enough to communicate back and ask for the SDV channel.
So what i have is - main line to three way splitter (passive) 1 for cable modem 1 for ceton and 1 for the SDV. For the two SDV (tuning adapters) I have one two way splitter. You should get around at least a 10-15 signal level from your cable company off your main line - so the drop to a 3 way splitter should be fine.
People that have to do more splits then me usually get a drop amp.. Which is something I could do as well. You just can't (shouldn't) amplify your cable modem (though you can with a good amp cable companies use mutiple amplifiers of course). So if I did that I'd use the two way splitter - and get a 4 port drop amp. (Or use one port amp and a three way splitter - there are lots of ways to go here).
