Ceramique application
Expe
Using the guide from the arctic silver site.
Does that look alright?
I notice my temps can vary between the two cores about 5C while idle and 3C while under Orthos full load. Could that be because I put a little too much on the top? Or is that normal?
Pic of idle temps
Using scythe ninja rev B on e6300.
Thanks
the difference in temps on one core to another is normal. I apply differently, like the size of a grain or rice (or even alittle less). Im sure thats fine though.
Application technique is pretty much personal preference the only thing that really matters is that you cover the die with a very thin layer. Personally, I prefer to cover the full IHS or die with a very thin layer and then a small dab in the middle of the IHS to make sure that the die gets any air bubbles out of the contact.
Thanks for the feedback, temps are peaking at 53C after a while of load as i type this. I'm fairly satisfied.
