Ceph Disk Controller Throughput Article
Nite_Hawk
Hi Guys,
Just wanted to pass along an article I wrote that looks at how different disk controllers perform in a couple of different configurations with Ceph. The benchmark is just sending objects directly to the OSDs, so these tests are a bit lower level than something like FIO. I've got a ton of profiling and blktrace data to analyse and more tests to run, so hopefully I should have some deeper articles coming out in the future. Let me know if I screwed anything up or should have done anything different. :)
http://ceph.com/community/ceph-performance-part-1-disk-controller-write-throughput/
Thanks,
Mark
Interesting tests. Did you gather any information on latency while the RADOS instances were hitting the server? What stripe size did you use on the array for the RAID 0 tests?
Do you plan to do tests with all 36 disks in one Ceph cluster? How about benchmarking one OSD versus several using the same number of disks?
Hi!
I do have latency information provided by RADOS bench. Perhaps I'll do another quick article looking at that. I didn't gather latency information for each operation since it can have a performance impact. You can do that if you include high enough debug levels in the logs.
Raid stripe size was 64k. Next time I should probably pay more attention to making sure that max_sectors_kb is setup to try to avoid read-modify-writes. At this point I don't think it matters much though until we get the per-osd throughput up when using high performance block devices behind them.
Yes, I do plan to test a large disk configuration. It might have to be 32 since I accidently only bought 4 SAS9207s (and the system isn't too happy using the onboard SAS2208 controller with 4 SAS2308s installed). I've already got some test results with 24 OSDs and 8 SSDs for journals... :)
